Hi, I want to pick a point or draw a line/polygon on one my 3Dtileset. When I draw, the drawing is hiding behind the tileset. The line drawn is also hiding in some parts.
Please help me how to show the point/line or drawing on the 3dtileset with out hiding
I created the sandcastle to demonstrate this. Cesium Sandcastle[cesium_help|436x274
This is the screen shot of the problem I am having
Thank you reply. Sorry about the sandcastle. I thought the sandcastle would have saved. Anyway I am sharing the code I currently using. Please try it on one of the vertical antennas.
Cesium.Ion.defaultAccessToken = "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJlM2FmMDlkMS01M2IxLTQ3YTgtOTA5OS1hZDk0OWNhNjdmN2EiLCJpZCI6NDIxNDIsImlhdCI6MTYxMTA0NDE5OH0.0AVb7rKx3ZklO-o9CFhJkKi9tqNVP1X9USNxVfqs0PE";
var viewer = new Cesium.Viewer("cesiumContainer", {
selectionIndicator: false,
infoBox: false,
viewer.animation.container.style.visibility = 'hidden';
viewer.timeline.container.style.visibility = 'hidden';
viewer.scene.globe.depthTestAgainstTerrain = false;
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK);
viewer.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
var tileset = viewer.scene.primitives.add(
new Cesium.Cesium3DTileset({
url: Cesium.IonResource.fromAssetId(373492),
tileset.readyPromise.then(function (tileset) {
//viewer.zoomTo(tileset, new Cesium.HeadingPitchRange(0, -0.5, 0));
viewer.zoomTo(tileset);
// Home button override to zoom to tileset
viewer.homeButton.viewModel.command.beforeExecute.addEventListener(function (e) {
e.cancel = true;
function createPoint(clickPosition) {
var point = viewer.entities.add({
position: clickPosition,
point: {
show: true,
color: Cesium.Color.Yellow,
pixelSize: 7,
heightReference: Cesium.HeightReference.NONE,
return point;
// Drawing mode. Initially only line is supported
var drawingMode = "line";
function drawShape(positionData) {
var shape;
shape = viewer.entities.add({
polyline: {
positions: positionData,
material: new Cesium.ColorMaterialProperty(
Cesium.Color.YELLOW.withAlpha(0.7)),
clampToGround: false,
width: 3,
return shape;
var activeShapePoints = [];
var activeShape;
var floatingPoint;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(function (event) {
var position = viewer.scene.pickPosition(event.position);
if (Cesium.defined(position)) {
if (activeShapePoints.length === 0) {
floatingPoint = createPoint(position);
activeShapePoints.push(position);
var dynamicPositions = new Cesium.CallbackProperty(function () {
return activeShapePoints;
}, false);
activeShape = drawShape(dynamicPositions);
if (Cesium.defined(floatingPoint)) {
var newPosition = viewer.scene.pickPosition(event.endPosition);
if (Cesium.defined(newPosition)) {
floatingPoint.position.setValue(newPosition);
activeShapePoints.pop();
activeShapePoints.push(newPosition);
function terminateShape() {
drawShape(activeShapePoints);
viewer.entities.remove(floatingPoint);
viewer.entities.remove(activeShape);
floatingPoint = undefined;
activeShape = undefined;
terminateShape();
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
