It seems like all of the options to draw an image on a globe use the paradigm that cesium will load the file (jpg, bmp, etc) from disk for you. I have a buffer that I did some processing on after I loaded the initial image, and I would like to display the geo-rectified result on a globe.
No bug, just looking for help! I have no idea where to start.
We currently have multiple applications that do different processing on geolocated imagery. Each of these applications ends with a bitmap of resultant data. We would like to draw the data on a globe (and sometimes the data isn't square, it becomes an irregular polygon), but we do have the coordinates for each corner. What's the best way to show this on the globe without writing the result to disk and then having cesium load it?
Here is an example of what I'm looking to do: https://pasteboard.co/HzcKliV.png
Cesium 1.48
Windows 10 Enterprise
Chrome v68
Thanks! I'm happy to clarify anything.
