Efficient Primitives
Hello all,
On my globe I am, on load, drawing about 5 primitives (billboard, labels etc).
Then, on a set interval, I use the position of a satellite, say, and calculate the footprint as a polyline (as I can’t seem to figure out how to draw a polygon with no fill but just an outline). This polyline I add with primitives.add(footprint).
The problem with this is that after a while I have hundreds of _primitives loaded, and it slows the viewer down massively.
What is the best way to update the polyline collection / primitives?
Pseudo code:
var primitives = scene.getPrimitives();
var footprintLines = new Cesium.PolylineCollection();
function tick(xyz){
var satelliteLocation = xyz;
frame = calculatedfromxyz;
var footprint = footprintLines.add();
footprint.setPositions(frame);
primitives.add(footprintLines);
I can see that there is an ‘update’ function on the primitives but unsure how to use it.
Thanks for any help.
Toby
Hi Toby,
If tick is called n times, then footprintLines will be updated n times for each frame. You only need to add the primitive once. Try:
function tick(xyz){
Dan
Perfect. Exactly what I was after. Thanks Dan.
