ElevationRamp to Polyline
Is it possible to apply ElevationRamp to Polyline?
        var dataSourcePromise = Cesium.GeoJsonDataSource.load('rohace.geojson', {});
        function getColorRamp() {
            var ramp = document.createElement('canvas');
            ramp.width = 100;
            ramp.height = 1;
            var ctx = ramp.getContext('2d');
            var values = [0.0, 0.045, 0.1, 0.15, 0.37, 0.54, 1.0];
            var grd = ctx.createLinearGradient(0, 0, 100, 0);
            grd.addColorStop(values[0], '#000000'); //black
            grd.addColorStop(values[1], '#2747E0'); //blue
            grd.addColorStop(values[2], '#D33B7D'); //pink
            grd.addColorStop(values[3], '#D33038'); //red
            grd.addColorStop(values[4], '#FF9742'); //orange
            grd.addColorStop(values[5], '#ffd700'); //yellow
            grd.addColorStop(values[6], '#ffffff'); //white
            ctx.fillStyle = grd;
            ctx.fillRect(0, 0, 100, 1);
            return ramp;
        var material1 = new Cesium.Material.fromType('ElevationRamp');
        shadingUniforms = material1.uniforms;
        shadingUniforms.minHeight = -414;
        shadingUniforms.maxHeight = 8777;
        shadingUniforms.image = getColorRamp();
        viewer.dataSources.add(dataSourcePromise).then(function(){
            viewer.dataSources.get(0).entities.values.forEach(function(entity) {
                if (entity.polyline) {
                    entity.polyline.material = material1;
I want to draw polyline (from geojson) and color it based on elevation. I tried creating material from ElevationRamp as seen here https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Globe%20Materials.html but it doesn't work. Either I'm missing something or it just doesn't work for polyline.
Cesium 1.52, Chromium 70, Linux
Yeah unfortunately, as you’ve discovered, the Elevation Ramp is a globe material, and can’t be applied to other types of geometry (more on why that is in this post).
You might need to write a custom material/appearance for your line. This might be a good place to start:
If you get it working please post a code snippet here! I don’t think we have any examples of a custom appearance on a polyline off the top of my head on our docs, so it would be a useful reference.
hi , have you solve this problem?
No I haven’t. I abondoned this task for now.
