I am using EllipsoidGraphics to draw beams that have a value that determines their color from a color gradient. I am having an issue where two beams with the same color value will render with visibly different shades because of lighting effects.
After setting shadows: ShadowMode.DISABLED
on both the EllipsoidGraphics and the Entity that contains it, I can see these lighting effects are still happening, which means it must be caused by the distance to the light source rather than the shadow of the globe.
I can see that both EllipsoidSurfaceAppearance and MaterialAppearance allow for a flat
property that seems to be what I need. My issue is that neither EllipsoidGraphics nor the container entity has no appearance
property to set.
How can I get flat shading for my EllipsoidGraphics? Is there no way other than rewriting the entity as a Primitive?
Any help would be appreciated, I am still fairly new to this so apologies for any incorrect terminology.
Edit 1: The only fix I have found so far is to set the intensity of the sunlight to 0, like so:
const sunlight = new Cesium.SunLight({
color: Cesium.Color.WHITE,
intensity: 0.0
viewer.scene.light = sunlight;
The issue with this is that all colors are now darker, as if they are all under a shadow. Is there is any way to just show the actual css color I am trying to show, with no lighting effects?
