I’m new to Cesium-Native and currently working on an OpenGL + Cesium-Native project to render 3DTiles and Ellipsoid. While the 3DTiles render correctly, the Ellipsoid’s meshes are distorted and the origin is not centered on the sphere. I’m rendering a unit sphere, not in the WGS84 Ellipsoid, so I don’t think I should encounter numerical issues. I’ve borrowed a lot of code from Cesium-Unity, but I still can’t figure out where the bug is. Below are the relevant code snippets I think might be related. I’d really appreciate it if someone with experience could take a look. Thank you!
void *PrepareRendererResources::prepareInMainThread(Cesium3DTilesSelection::Tile &tile, void *pLoadThreadResult_) {
// SPDLOG_INFO("---------prepare in main---------");
const Cesium3DTilesSelection::TileContent &content = tile.getContent();
const Cesium3DTilesSelection::TileRenderContent *pRenderContent = content.getRenderContent();
if (!pRenderContent) {
return nullptr;
std::unique_ptr<LoadThreadResult> pLoadThreadResult(static_cast<LoadThreadResult *>(pLoadThreadResult_));
std::vector<std::shared_ptr<Mesh>> meshes = pLoadThreadResult->meshes;
const std::vector<CesiumPrimitiveInfo> &primitiveInfos = pLoadThreadResult->primitiveInfos;
const CesiumGltf::Model &model = pRenderContent->getModel();
glm::dmat4 tileTransform = tile.getTransform();
tileTransform = CesiumGltfContent::GltfUtilities::applyRtcCenter(model, tileTransform);
CesiumGltfContent::GltfUtilities::applyGltfUpAxisTransform(model, tileTransform);
int32_t meshSize = meshes.size();
if (!meshSize) {
return nullptr;
std::string name = "glTF";
auto urlIt = model.extras.find("Cesium3DTiles_TileUrl");
if (urlIt != model.extras.end()) {
name = urlIt->second.getStringOrDefault("glTF");
size_t meshIndex = 0;
GameComponent* tilesetComponentPtr = pTileset;
CesiumGeoreference* georeferencePtr = pTileset->getGeoreference();
model.forEachPrimitiveInScene(
-1,
[tilesetComponentPtr, georeferencePtr, &meshes, &primitiveInfos, &meshIndex, &tile, &tileTransform](const CesiumGltf::Model &gltf,
const CesiumGltf::Node &node,
const CesiumGltf::Mesh &mesh,
const CesiumGltf::MeshPrimitive &primitive,
const glm::dmat4 &transform) {
auto positionAccessorIt = primitive.attributes.find("POSITION");
if (positionAccessorIt == primitive.attributes.end()) {
return;
int32_t positionAccessorID = positionAccessorIt->second;
CesiumGltf::AccessorView<glm::vec3> positionView(gltf, positionAccessorID);
if (positionView.status() != CesiumGltf::AccessorViewStatus::Valid) {
return;
const CesiumPrimitiveInfo &primitiveInfo = primitiveInfos[meshIndex];
glm::dmat4 modelToEcef = tileTransform * transform;
auto meshInstancePtr = meshes[meshIndex];
meshInstancePtr->setParent(tilesetComponentPtr);
CesiumGlobeAnchor* anchor= new CesiumGlobeAnchor(georeferencePtr);
meshInstancePtr->addGlobeAnchor(anchor);
anchor->setDetectTransformChanges(false);
anchor->setAdjustOrientationForGlobeWhenMoving(false);
anchor->updateLocalToGlobeFixedMatrixAndEcef(modelToEcef);
anchor->setParent(meshInstancePtr.get());
const CesiumGltf::Material *pMaterial = CesiumGltf::Model::getSafe(&gltf.materials, primitive.material);
if (pMaterial) {
setGltfMaterialParameterValues(gltf, primitiveInfo, pMaterial, meshes[meshIndex++]);
return new CesiumGltfObject{std::move(meshes), std::move(pLoadThreadResult->primitiveInfos)};
CesiumGeospatial::LocalHorizontalCoordinateSystem CesiumGeoreference::createCoordinateSystem() {
double scaleToMeters = 1.0 / scale;
if (originPlacement == CesiumGeoreferenceOriginPlacement::TrueOrigin) {
glm::dmat4 localToEcef(
glm::dvec4(scaleToMeters, 0.0, 0.0, 0.0),
glm::dvec4(0.0, scaleToMeters, 0.0, 0.0),
glm::dvec4(0.0, 0.0, scaleToMeters, 0.0),
glm::dvec4(0.0, 0.0, 0.0, 1.0));
return CesiumGeospatial::LocalHorizontalCoordinateSystem(localToEcef);
if (originAuthority == CesiumGeoreferenceOriginAuthority::EarthCenteredEarthFixed) {
return CesiumGeospatial::LocalHorizontalCoordinateSystem(glm::dvec3(ecefX, ecefY, ecefZ),
CesiumGeospatial::LocalDirection::East,
CesiumGeospatial::LocalDirection::Up,
CesiumGeospatial::LocalDirection::South,
scaleToMeters,
ellipsoid->getNativeEllipsoid());
return CesiumGeospatial::LocalHorizontalCoordinateSystem(glm::dvec3(longitude, latitude, height),
scaleToMeters,
void Mesh::draw(Shader& shader, glm::dmat4& modelMatrix) {
glm::dmat4 mtx = transform * modelMatrix; // transform equals modelToEcef of `anchor-
shader.setMat4("model", glm::mat4(mtx)); >updateLocalToGlobeFixedMatrixAndEcef(modelToEcef);`
