EllipsoidSurfaceAppearance’s fragmentShaderSource not work with GroundPrimitive
the example is below
I know the fragmentShaderSource in the example is not right
my question is
the EllipsoidSurfaceAppearance’s fragmentShaderSource even not be executed by computer.
Hi @zxc1987,
Thank you for sharing this with the community! I was able to successfully run your sandcastle demo. Can you please share some more information on your intended use case? I am still not quite sure what is broken here.
I am looking forward to learning more.
Sam
Hi @sam.rothstein
You can see my Sandcastle code in line 51
I give a blue color (not red color) in custom fragmentShaderSource
the problem is the fragmentShaderSource don’t work
i know the fragmentShaderSource code is not right in cesium.
but the problem is the cesium don’t even execute the fragmentShaderSource code.
Hi @zxc1987,
I am not sure if I fully understand the context here. I may have to take some time to get up to speed with how we handle shaders in CesiumJS. In the meantime, if you think this is a bug that needs to be addressed, I recommend opening up an issue on our GitHub page.
Sam
