I have a model that has its reference frame not exactly in the center of the model.
I would also like to display the path of the model, which ideally should be in the center of the model. Thus, I would like to apply an offset transform to the path or model.
position: W_t_W_M__sample,
orientation: q_W_M__sample,
model: {
uri: resource,
shadows: Cesium.ShadowMode.ENABLED,
availability: new Cesium.TimeIntervalCollection([new Cesium.TimeInterval({
start: start,
stop: stop
path: {
resolution: 1,
material: new Cesium.PolylineGlowMaterialProperty({
glowPower: 0.1,
color: Cesium.Color.YELLOW
width: 10,
// possibility to add some sort of offset?
There are two option:
Having some sort of offset in an entity would be nice
Adding another entity with a new sample position just for the path
For the second option: How could I have two entities running both at the same time?
All the latest and newest at the time of writing Thank you very much!
