I have an application that will use a lot of the features within cesium at the same time. I’ll have 100-5000 billboards, lines, 3D objects, and kml objects all being drawn at the same time. I also need to have some level of grouping which seems to be mostly supported through the parent property of the entites member add method. I’m just curious if anyone has any advice of the best practices when it comes to using Collections vs Entities for grouping. Should I use billboard collections for the billboards? and are their any options for grouping with in a collection?
TIA,
Scott
