How to position the label on top of entity model 30 meters?
Hi @fation,
Thank you for your question. The solution depends on the UI that you are looking for. I would recommend experimenting with the member variables of the Label object. In particular, eyeOffset might yield the desired result.
https://cesium.com/learn/cesiumjs/ref-doc/Label.html?classFilter=label
-Sam
