Hi
I will display label above 3dmodel in a entity and above other objects and earth. how can i set zorder ?
Hi
Hi @mohamad,
Thank you for your question. I recommend checking out the following community forum post for some more context:
It seems like the key here can be found in the Label documentation.
In particular, the member eyeOffset can be used to arrange multiple label or objects at the same position. I recommend using this for your implementation. Please let me know if you have any other questions or concerns.
Sam
