I see the above error, and nothing else, when adding a new 3d tile created with Obj2Tiles. Is there any way to get more info or validate a tileset? I believe the Obj2Tiles tool still uses b3dm, is this not supported anymore perhaps? Any suggestions how to improve this workflow if there are a lot of tiles I’d like to add to ion?
If I understand your sitation correctly you are trying to upload a 3D tileset to Ceisum ion for hosting. This is a supported workflow. You should be able to select the 3D Tiles option when adding the data to directly upload your 3D Tilesets without tiling.
Can you provide the asset id that failed? That will let us look up the logs to get more information about why it failed.
Thanks @mdc9001 for your answer. It appears my issue was caused by partially uploading a tileset by accident. I had better luck just dragging and dropping the entire folder to get all needed files uploaded. This ended up solving my problem. I was just confused by the ambiguous error message.
