Error constructing CesiumWidget.
I use webstorm with chrome as browser and I have started to get this on startup. Any help would be appreciated. Cesium 1.29
RuntimeError: The browser supports WebGL, but initialization failed.
Error
    at new RuntimeError (http://localhost:63342/Cesium-1.29%202/Source/Core/RuntimeError.js:43:19)
    at new Context (http://localhost:63342/Cesium-1.29%202/Source/Renderer/Context.js:213:19)
    at new Scene (http://localhost:63342/Cesium-1.29%202/Source/Scene/Scene.js:218:23)
    at new CesiumWidget (http://localhost:63342/Cesium-1.29%202/Source/Widgets/CesiumWidget/CesiumWidget.js:256:25)
    at new Viewer (http://localhost:63342/Cesium-1.29%202/Source/Widgets/Viewer/Viewer.js:396:28)
    at http://localhost:63342/Cesium-1.29%202/Apps/CesiumViewer/CesiumViewer.js:56:18
    at Object.execCb (http://localhost:63342/Cesium-1.29%202/ThirdParty/requirejs-2.1.20/require.js:1678:33)
    at Module.check (http://localhost:63342/Cesium-1.29%202/ThirdParty/requirejs-2.1.20/require.js:878:51)
    at Module.<anonymous> (http://localhost:63342/Cesium-1.29%202/ThirdParty/requirejs-2.1.20/require.js:1128:34)
    at http://localhost:63342/Cesium-1.29%202/ThirdParty/requirejs-2.1.20/require.js:131:23
What version of Chrome are you using? Also, what is your OS and graphics driver?
Try running in incognito mode and see if that fixes the problem.
-Hannah
Sorry for not following your "how to get a good response on question post" I updated my driver and problem solved. Will try to be more specific next time and do proper research before asking. (Under deadline and I panicked) Thanks for your great support.
No problem! I’m glad you were able to figure it out =)
-Hannah
