Error visualising with firefox 57.0.4
Hi ! the cesium app on your homepage crashed when trying to use it with Firefox 57.0.4 64 bits
Here's the error message :
RuntimeError: Program failed to link. Link log:
Failed to create vertex shader, result: 0x887A0005.
t@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:434:17742
m@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:440:18114
y@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:440:19828
d.prototype._bind@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:440:20843
z@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:483:16509
F.prototype.draw@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:483:20146
r.prototype.execute@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:439:15520
Be@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:490:28223
Ge@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:490:30288
Qe@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:491:5813
je@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:491:3769
nt@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:491:11167
Ee.prototype.render@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:491:19119
P.prototype.render@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:492:27486
t@https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/CesiumViewerStartup.js:492:11663
Just trying to use the webapp example on the cesium homepage
The one on your homepage, windows 8.1 64 bits, firefox 57.0.4 64 bits.
Best regards.
Sounds like a hardware problem. Have you run webglreport.com on your hardware?
