Kevin,
I’ll shoot you an email with a usable demonstration tomorrow. I can share my imagery as it’s produced internally. I can also definitely reproduce this by changing one of my two tiler applications to return a 500 error resulting in 50% of the requests failing. This leads to Cesium crashing, even with 1.8 (though I run a forked master).
jbo023
December 14, 2016, 7:21pm
23
Ho,
i also just found this problem. Here is a very short Sandcastle example which replicates the problem.
var options = {
“url” : “http://hosting.virtualcitysystems.de/demos/temp/tms ”,
“fileExtension”: “jpg”,
“maximumLevel”: 19,
“minimumLevel”: 13,
“rectangle”:Cesium.Rectangle.fromDegrees(13.39657249732205, 52.49127999816725, 13.42722986993895, 52.50998943590507),
“show”:true
var provider = Cesium.createTileMapServiceImageryProvider(options);
“imageryProvider” : provider,
“baseLayerPicker”:false
Jannes
Kevin, Do you have an acceptable demo to show the problem now?
Scott
Yes, thanks for the example, Jannes, I’m able to see the problem with that.
I just opened a pull request with a fix for this issue:
https://github.com/AnalyticalGraphicsInc/cesium/pull/4763
It wasn’t what I originally thought, so thanks for putting together the test case, Jannes!
Kevin
patrick
December 19, 2016, 12:51pm
27
Kevin’s fix was just merged into master and will ship in Cesium 1.29 on January 2.
Patrick
jbo023
December 19, 2016, 3:12pm
28
Thanks Kevin,
I just testet your fix and it is working now.
Jannes
That’s great news! Thank you!
