When I try to add “Cesium World Terrain + Bing Maps Aerial”, I always get the error:
Received an error from the Bing Maps imagery metadata service: Your request could not be completed because there was a problem with the service.
I am very confused, could you please help me?
The output log is as follows:
LogSlate: Window ‘Select a Cesium ion Token’ being destroyed
LogEditor: Attempting to add actor of class ‘Cesium3DTileset’ to level at 0.00,0.00,0.00
LogCesium: Loading tileset for asset ID 0
LogCesium: Loading tileset for asset ID 0 done
LogCesium: Loading tileset for asset ID 1
LogCesium: Loading tileset for asset ID 1 done
LogHttp: Warning: 000007CA74820500: request has been successfully processed. URL: https://dev.virtualearth.net/REST/v1/Imagery/Metadata/Aerial?incl=ImageryProviders&key=AmXdbd8UeUJtaRSn7yVwyXgQlBBUqliLbHpgn2c76DfuHwAXfRrgS5qwfHU6Rhm8&uriScheme=https, HTTP code: 500, content length: 609, actual payload size: 609, elapsed: 0.26s
LogHttp: Warning: 000007CA74820500 Response Header Date: Thu, 09 May 2024 14:05:21 GMT
LogHttp: Warning: 000007CA74820500 Response Header Content-Type: application/json; charset=utf-8
LogHttp: Warning: 000007CA74820500 Response Header Content-Length: 609
LogHttp: Warning: 000007CA74820500 Response Header Connection: keep-alive
LogHttp: Warning: 000007CA74820500 Response Header Access-Control-Allow-Headers: Content-Type,X-FD-Features,X-FD-FLIGHT,PreferAnonymous
LogHttp: Warning: 000007CA74820500 Response Header Access-Control-Allow-Methods: POST, GET, OPTIONS
LogHttp: Warning: 000007CA74820500 Response Header Access-Control-Allow-Origin: *
LogHttp: Warning: 000007CA74820500 Response Header Alt-Svc: h3=“:443”; ma=86400
LogHttp: Warning: 000007CA74820500 Response Header Cache-Control: no-cache
LogHttp: Warning: 000007CA74820500 Response Header X-BM-FE-Elapsed: 1, 1
LogHttp: Warning: 000007CA74820500 Response Header X-BM-TraceID: 5acd860227639e887bdcdcf835e5b733
LogHttp: Warning: 000007CA74820500 Response Header X-BM-Srv: mapsplatform-frontend-7cb844f95f-52m78
LogHttp: Warning: 000007CA74820500 Response Header x-azure-ref: 20240509T140521Z-r1dfb5f8656r92jf8wua4mdpkg000000083g000000006m8d
LogHttp: Warning: 000007CA74820500 Response Header X-Cache: CONFIG_NOCACHE
LogCesium: Error: [2024-05-09 22:05:20.248] [error] [RasterOverlayCollection.cpp:127] Received an error from the Bing Maps imagery metadata service: Your request could not be completed because there was a problem with the service.
