Cesium World Terrain can't show Bing Maps Aerial imagery
The project is CesiumForUnrealSamples
And I’m in the level:09_Cesium Material Editing
but There is no images on terrain,I only can see a blue earth
What’s wrong with my cesium plungin?
Are other levels working? Are there any messages in the Output Log? My best guess is that you’re using an old version of the Samples project and the Cesium ion token has expired. You should see a “Token Troubleshooting” panel pop up if that’s the case, though.
Thans for your reply
Every levels are not working , When i created a new project ,it not working either
In the new project , add “Cesium World Terrain + Bing Maps Aerial imagery” by clicking the button next to that entry. There is no CesiumCameraManager in the World Outliner.
I try to create a new token or change other token ,but it also not working
I use UE5.03
When i use cesium plugins first time,everything is ok ,and used for somedays(about a week) it will became something wrong,I have no idears what wrong with the cesium
I solve this problem by change another computer, After a few days , the other computer have the same problems ,
Outputlog :
Look forward to your reply
@Kevin_Ring
Did you try adding a “Cesium SunSky” to your level, too? You don’t have any lights in your screenshot, so that could be why everything is black.
Are you using some sort of remote desktop? Even if you’re not, make sure that Realtime is enabled in the viewport:
It’s working!!!
I actually use remote desktop sometimes, set Realtime is enabled in the viewport solved my problem
Thank you very much!!!
