I have a case where I always want to cast a shadow from a 3d model, regardless of time of day. I've searched quite extensively (and probably spent about 4-5 hours trying to debug/find a workaround. The closest I've come is https://groups.google.com/forum/#!topic/cesium-dev/q5G3jBLqtJQ suggesting to hack the Cesium JS source code, but that is from 2016 and the source code has changed significantly since.
I've tried:
- All shadow configurations I could think of
- Setting the camera in any way I could think of
Unfortunately I rely on the date and time for the timeline, so I can't hard code the time to when the sun is up at that point.
Specifically, I want this to cast a shadow:
<code>
infoBox: false,
selectionIndicator: false,
shadows: true,
terrainShadows: Cesium.ShadowMode.ENABLED,
shouldAnimate: true,
terrainProvider: Cesium.createWorldTerrain()
var cesiumAir = viewer.entities.add({
height : 20.0,
model : {
uri : '../../../../Apps/SampleData/models/CesiumAir/Cesium_Air.glb'
var entity = cesiumAir;
entity.position = Cesium.Cartesian3.fromRadians(1.81503, 0.02356,30);
viewer.clock.currentTime = Cesium.JulianDate.fromIso8601('2018-11-20T17:33:29Z');
viewer.clock.multiplier = 1.0;
viewer.trackedEntity = cesiumAir;
</code>
Shadow is a good way of intuitively indicating how far away an object is from the ground (and at what point in time the object touches the ground). My backup solution is to change color of the model or something like that, but it's quite an ugly hack
Any help would be greatly appreciated. Thank you so much for Cesium!
Latest Cesium, Latest Chrome, OS X.
