Gaussian Splats Apparently Breaking
I had a Gaussian splat asset in ion that was being displayed normally (Footage from Feb 9, 2026).
WhatsAppVideo2026-02-19at17.12.37-ezgif.com-optimize
And I noticed that recently that same asset is apparently “broken”, with splats often “lining up”. That happens at both “My assets” page on Ion, Sandcastle, and standalone apps:
Sandcastle code
Yeah, this is “tracked” in Regression in splats from PLY in 1.135 · Issue #13041 · CesiumGS/cesium · GitHub . The actual reason for this has not been identified, and there are several “levels” of things that don’t work as intended.
A workaround currently seems to be to not set the tileset.modelMatrix, but bake the desired transform into the root tile transform instead:
// Should work, but doesnt:
//tileset.modelMatrix = surfaceTransform;
// Use this instead:
function setTransformForRoot(tileset, transform) {
  // XXX This should not be done like this, but is a workaround
  // for https://github.com/CesiumGS/cesium/issues/13041
  const oldRootTransform = tileset.root.transform;
  const newRootTransform = Cesium.Matrix4.multiply(
    transform, oldRootTransform, new Cesium.Matrix4());
  tileset.root.transform = newRootTransform;
// Instead of setting the `modelMatrix`:
setTransformForRoot(tileset, surfaceTransform);
Here’s your sandcastle with this workaround applied:
Sandcastle with workaround
Thank you Marco for the workaround,
Just wanted to add that the model was generated using the iTwin Capture API’s, using GS_3DT as the reality data output reconstruction, from a set of photos.
The issue is in CesiumJS (and I’d even hesitate to call it a “regression”), so the title of the issue may be a bit misleading, but let’s hope that it will be addressed soon.
