Hi all,
I’m tiling 360° panorama spheres (GLB from Blender, panorama on the sphere’s inner surface) into 3D Tiles via the ion REST API, and I’m stuck on a tiling failure when I try to georeference them.
Asset creation request:
POST /v1/assets
“name”: “test-asset-10.jpg”,
“type”: “3DTILES”,
“options”: {
“sourceType”: “3D_MODEL”,
“position”: [46, 24, -80]
(position = [longitude, latitude, height].)
What happens:
| Options | Result |
| sourceType: “3D_MODEL” + position | Upload OK, then tiling ERROR at 9% |
| sourceType: “3D_MODEL” only | Tiling COMPLETE, but non-georeferenced (no root.transform) |
GET /v1/assets/{id} only reports “status”: “ERROR”, “percentComplete”: 9 — no error detail.
This worked for us earlier (we got proper georeferenced tilesets with root.transform placing the model on the globe); it started failing after a pipeline update around Feb 2026, which makes me think the handling of position for 3D_MODEL changed.
Questions:
- Is position still valid for sourceType: “3D_MODEL”? If it changed/was deprecated, what’s the current way to place a model at a lon/lat/height during tiling?
- Could an inward-facing sphere (degenerate/unusual geometry for a “real-world model”) be the reason the georeferencing path fails while the plain path succeeds?
- Is there any way to retrieve the detailed tiling error message via the API rather than the dashboard?
Any guidance appreciated — happy to share the GLB. Thanks!
