Hi, i’m currently having performance issue when i’m trying to add two sets of datasource to the map and clustering them. In other words, lag happens when every time I zoom the map. Any idea that I can do to lift the performance? Thank you and codes are posted below!
clusterStyle(dataSource, options, color) {
var dataSources = viewer.dataSources.add(dataSource, options)
dataSources.then(function (dataSource) {
var pixelRange = 30
var minimumClusterSize = 10
var enabled = true
dataSource.clustering.enabled = enabled
dataSource.clustering.pixelRange = pixelRange
dataSource.clustering.minimumClusterSize = minimumClusterSize
dataSource.clustering.clusterLabels = !enabled
var pinBuilder = new Cesium.PinBuilder()
dataSource.clustering.clusterEvent.addEventListener(function (
clusteredEntities,
cluster
cluster.label.show = false
cluster.billboard.show = true
cluster.billboard.id = cluster.label.id
cluster.billboard.verticalOrigin = Cesium.VerticalOrigin.BOTTOM
if (clusteredEntities.length >= 100) {
cluster.billboard.image = pinBuilder
.fromText(
clusteredEntities.length,
Cesium.Color.fromCssColorString(color[2]),
50
.toDataURL()
} else if (clusteredEntities.length >= 10) {
.fromText(
Cesium.Color.fromCssColorString(color[1]),
40
.toDataURL()
cluster() {
var that = this
for (var key in this.district) {
new Cesium.loadJson(
‘…/…/…/static/shapefile/’ + key + ‘/geo/rfgsd.json’
).then(function (data) {
if (data) {
var dataSource1 = new Cesium.CustomDataSource(‘public’)
var dataSource2 = new Cesium.CustomDataSource(‘non’)
var sum = 0;
for (var i = 0; i < data.length; i++) {
var name = data[i][‘name’]
var cat = data[i][‘cat’]
var dist = data[i].district
var num = data[i][‘num’]
var lon = data[i].geometry.x
var lat = data[i].geometry.y
sum += 1;
if (lon !== “NaN” && lat !== “NaN”) {
if (cat == ‘style1’) {
dataSource1.entities.add({
position: new Cesium.Cartesian3.fromDegrees(
parseFloat(lon),
parseFloat(lat)
layer: ‘rfgsd’,
district: dist,
number: num,
cat: ‘style1’,
billboard: {
image: ‘…/…/…/static/images/rf_pub.png’,
width: 30,
height: 30,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
HorizontalOrigin: Cesium.HorizontalOrigin.LEFT,
distanceDisplayCondition: new Cesium.DistanceDisplayCondition(
500.0
// 10000.0
label: {
text: name,
font: ‘14pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 2,
HeightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
0.0,
2000.0
} else if (cat == ‘style2’) {
dataSource2.entities.add({
layer: ‘rfgsd’,
district: dist,
number: num,
cat: ‘style2’,
parseFloat(lon),
parseFloat(lat)
billboard: {
image: ‘…/…/…/static/images/rf_non.png’,
width: 30,
height: 30,
500.0
// 10000.0
label: {
text: name,
outlineWidth: 2,
0.0,
2000.0
var options = {
camera: viewer.scene.camera,
canvas: viewer.scene.canvas,
var color1 = [’#D8BFD8’, ‘#9370DB’, ‘#7B68EE’]
var color2 = [’#DEB887’, ‘#FF7F50’, ‘#D2691E’]
that.clusterStyle(dataSource1, options, color1)
that.clusterStyle(dataSource2, options, color2)
var handler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas)
handler.setInputAction(function (movement) {
var pickedLabel = viewer.scene.pick(movement.position)
if (Cesium.defined(pickedLabel)) {
var ids = pickedLabel.id
if (Cesium.isArray(ids)) {
for (var i = 0; i < ids.length; ++i) {
ids[i].billboard.color = Cesium.Color.RED
}, Cesium.ScreenSpaceEventType.LEFT_CLICK)
The Cesium version is 1.40, and browser is Chrome 69.0.3497.81.
