I’m using the cesium sensors plugin with a .czml file generated in STK. The sensor volume appears for the Geoeye1_33331 satellite, but there is no global earth image.
I see the outline of the earth with atmosphere representation but there are on continents, oceans etc., just a black sphere.
I need to have the sensor volume capability running offline without any internet support.
I get the blank sphere when I define the cesiumContainer like this:
However when I try add the globe from a local source like this:
imageryProvider : Cesium.createTileMapServiceImageryProvider({
url : Cesium.buildModuleUrl(‘http://localhost:8080/Assets/Textures/NaturalEarthII’)
////url : Cesium.buildModuleUrl(‘Assets/Textures/NaturalEarthII’)
shouldAnimate : true,
baseLayerPicker : false,
geocoder : false
I get nothing at all, just a blank browser window. I’ve tried placing the Assets folder in different places
in the cesium-sensors folder but none of them have worked so far.
I will have .czml files describing a scenario including satellites, and missiles.
I need to add sensor volumes to some of the satellites in the scenario.
The sensors will have different fields of view and viewing angles.
v1.59 with Edge browser
