I try to load a gltf/glb model in cesium, it works fine on my Mac, but failed on my iPhone.
I got the following error:
[Cesium WebGL] Vertex shader compile log: ERROR: too many uniforms
[Cesium WebGL] Vertex shader translation failed.
RuntimeError: Vertex shader failed to compile. Compile log: ERROR: too many uniforms
Is there any limitation for the model file?
After check the WebGLReport.com, I guess the problem is caused by the value of “ Max Vertex Uniform Components:” It’s 2048 for iPhone, while my model has 2.1K vertex.
Do I have to simplify my models?
PS: I got the same result for gltf and glb format, no matter enabled the Draco compress or not.
You can test the limitations of gltf loading in Cesium with some example models here. It’s possible that you will need to simplify the model. Is it possible for you to send us the asset id of the model on Cesium ion or a copy of the model via support@cesium.com for testing?
I was able to find this issue which is very similar to what you are experiencing, except it is from the fragment shader: Fragment shader failed to compile. too many uniforms · Issue #7823 · CesiumGS/cesium · GitHub. I posted a short follow-up in that issue. Please add any additional information for your case (iPhone version, browser, etc.). It looks like there are some suggestions on how to fix the issue, if you are up for opening a PR for the fix!
