Is there some way to improve / remove the gray complexion of the the view? I replaced the skybox with completely white images, but its still a very dull gray color.
thanks. I’ve attached an image.
Yeah I wouldn’t expect the map to look this gray. Can you post a Sandcastle (https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/) example of your code so I can take a look?
Alright, so this is an issue because we implemented HDR a few versions ago. If you turn if off with:
smallviewer.scene.highDynamicRange = false;
You can see the background becomes correctly white. With HDR, you can get whites that are “whiter than white”, so the fully white image you set as a Skybox, after tonemapping, because that dull grey. I believe the default sky box in Cesium is an HDR image so it uses that full range.
thanks very much Omar!
