Hello everyone, I’m new to Cesium and have been using it to create aerial footage for some time. However, I’ve noticed that whenever I try to get closer to the ground, the surface appears wavy. For example, the runway (see attached screenshots) should be flat, but it isn’t. The airport coordinates are: 22.65561349424696, 88.44573379235878.
Could anyone please let me know how to fix this issue? Thanks in advance!
It’s possible that some regions on Cesium World Terrain are outdated due to the older height data. There are some suggestions on this other forum thread here:
You could also try using the From Ellipsoid option on Cesium3DTileset to build on a smooth ellipsoidal surface. However, this does smooth out the entire Earth, so it will look less realistic from afar.
