Hi
I want to bulid the roadl myself. But as you can see the world terrain ground is not flat enough.
Is there any way to use a flat world terrain?
Hello @AOCG,
We are working on implementing a flat world terrain for use cases like this. You can track the status of that feature here: Generate MSL ellipsoid tiles as an alternative to Cesium World Terrain · Issue #817 · CesiumGS/cesium-unreal · GitHub
In the meantime, you can try the workaround described in this comment: Using a global terrain layer without height detail - #10 by agallegos
-Alex
Thanks!
I will test the second one you mentioned!
Old thread, but updating for future’s sake.
Support for WGS84 ellipsoid terrain has been added to Cesium for Unreal. It will be available in the next release!
