Patrick, thers also the 0.40 cm resolution processed DTM from the point clouds. I been trying to figure out to download the AGI terrain server but dint find anyhting that I could download and try.
Would be cool to see this data in the terrain server
http://cesiumjs.org/data-and-assets/terrain/stk-world-terrain.html
Example info for small part of the DTM.
Files: Y:\DTM\DTM_605_65_TIF_UTM32-ETRS89\dtm_1km_6055_656.tif
Size is 2500, 2500
Coordinate System is:
PROJCS[“ETRS89 / UTM zone 32N”,
GEOGCS[“ETRS89”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,9],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“25832”]]
Origin = (656000.000000000000000,6056000.000000000000000)
Pixel Size = (0.400000000000000,-0.400000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=DEFLATE
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 656000.000, 6056000.000) ( 11d24’59.72"E, 54d37’38.21"N)
Lower Left ( 656000.000, 6055000.000) ( 11d24’57.80"E, 54d37’ 5.88"N)
Upper Right ( 657000.000, 6056000.000) ( 11d25’55.43"E, 54d37’37.09"N)
Lower Right ( 657000.000, 6055000.000) ( 11d25’53.50"E, 54d37’ 4.77"N)
Center ( 656500.000, 6055500.000) ( 11d25’26.61"E, 54d37’21.49"N)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
NoData Value=-9999
