Heading/Pitch/Roll to Quaternions... ... and back
Here’s yet another from me!
This relates to an aircraft - I use local heading, pitch and roll and convert it into a quaternion using the transform ‘headingPitchRollQuaternion’. The attitude of the aircraft is spot-on.
center = Cesium.Cartesian3.fromDegrees(-0.2080299, 51.1473961, 210.00);
hdg.addSample(Cesium.JulianDate.fromIso8601(‘2012-08-04T13:16:07Z’), Cesium.Transforms.headingPitchRollQuaternion(center, Cesium.HeadingPitchRoll.fromDegrees(166.2, -0.9, 0.2)));
A a later point I then use the transform ‘Cesium.HeadingPitchRoll.fromQuaternion’ to extract the headingPitchRoll from the quaternion and finally the toString() method to put heading, pitch and roll into a string.
The values in the string appear to be earth-oriented (e.g., affected by the lat/lon) rather than the local heading, pitch and roll. When the nose of the aircraft is [locally] vertical, the pitch is 0.89 radians or 51.1° : the same as the latitude.
I’m obviously missing a transform but can’t find one that is the direct inverse of ‘Cesium.Transforms.headingPitchRollQuaternion’?
Quaternions make my head hurt!
Hugh
Here's yet another from me!
'headingPitchRollQuaternion'. The attitude of the aircraft is spot-on.
hdg.addSample(Cesium.JulianDate.fromIso8601('2012-08-04T13:16:07Z'),
A a later point I then use the transform 'Cesium.HeadingPitchRoll.
fromQuaternion
<https://cesiumjs.org/Cesium/Build/Documentation/HeadingPitchRoll.html?classFilter=headingPitchRoll#.fromQuaternion&gt;&#39;
<https://cesiumjs.org/Cesium/Build/Documentation/HeadingPitchRoll.html&gt;
<https://cesiumjs.org/Cesium/Build/Documentation/HeadingPitchRoll.html#toString&gt;
I'm obviously missing a transform but can't find one that is the direct
inverse of 'Cesium.Transforms.headingPitchRollQuaternion'?
Hugh
You received this message because you are subscribed to a topic in the
Google Groups "cesium-dev" group.
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/cesium-dev/sxqmI-NPqpg/unsubscribe.
To unsubscribe from this group and all its topics, send an email to
cesium-dev+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
From what I understood, you should “only” remove the rotation from local frame (by default East North Up local frame) to retrieve the desired result.
one solution
const scratchInvEastNorthUpFrame = new Matrix4();
const scratchInvRotation = new Matrix3();
const scratchInvRotationQ = new Quaternion();
const scratchLocalQuaternion = new Quaternion();
const scratchLocalHpr = new HeadingPitchRoll();
function getLocalHpr(origin, quaternion) {
    const eastNorthUpFrame = Transforms.eastNorthUpToFixedFrame(origin);
    const invEastNorthUpFrame = Matrix4.inverse(eastNorthUpFrame, scratchInvEastNorthUpFrame);
    const invRotation = Matrix4.getRotation(invEastNorthUpFrame, scratchInvRotation);
    const invRotationQ = Quaternion.fromRotationMatrix(invRotation, scratchInvRotationQ);
    const localQuaternion = Quaternion.multiply(invRotationQ, quaternion, scratchLocalQuaternion);
    return HeadingPitchRoll.fromQuaternion(localQuaternion, scratchLocalHpr);
