I'm animating a model based on recorded data, using lat/lon, altitude and heading/pitch/roll. The model is animated along a path. This works well, but then I have a case where the heading is faulty and I'm trying to correct it. I'm trying to use heading from VelocityOrientationProperty but with my own pitch and roll.
This is not a bug in Cesium, I just can't figure out the math.
I think I'm confusing my units, since I can't get even get this working:
let q = orientation_velocity.getValue(time);
let velocity_hpr = Cesium.HeadingPitchRoll.fromQuaternion(q);
let orientation = Cesium.Transforms.headingPitchRollQuaternion(
posSamples.getValue(time),
velocity_hpr
orientationSamples.addSample(time, orientation);
If I convert a Quaternion to a HeadingPitchRoll, then convert HPR to a Quaternion (using the same position) shouldn't it work? Obviously it's fictitious example, but if I can't even get that to work.. the above sample gives me the same odd behaviour as TRY #2 below, i.e the forward tip of the model points upwards.
Longer Story:
When I have a working heading (these are executed in a for loop):
let hpRoll = new Cesium.HeadingPitchRoll(
Cesium.Math.toRadians(data['HEADING'][i]),
Cesium.Math.toRadians(data['PITCH'][i]),
Cesium.Math.toRadians(data['BANK'][i]),
positions[i], // position
hpRoll,
Cesium.Ellipsoid.WGS84,
Cesium.Transforms.northWestUpToFixedFrame,
I can also use the VelocityOrientationProperty:
TRY #1:
orientation_velocity = new Cesium.VelocityOrientationProperty(posSamples);
Gives a perfect heading along the path, but obviously without PITCH/ROLL.
However, now I'm trying to use heading from VelocityOrientationProperty but my own PITCH and BANK.
TRY #2 (TLDR: 90 degrees (forward tip of the model points upwards)
// Replace pitch and roll from VelocityOrientationProperty Quaternion
hpRoll['pitch'] = velocity_hpr['pitch']
hpRoll['roll'] = velocity_hpr['roll']
hpRoll,
This creates a model where the front of the model points pretty much straight up and not forward.
TRY #3: (TLDR: Doesn't point straight forwards, rotates 180 degrees randomly when turning)
let heading = Cesium.Math.toDegrees(velocity_hpr['heading']);
velocity_hpr['heading'],
hpRoll,
