how can i build custom primitive with my vertex data
Hi,My Name is Zhao.
And Now I am confused in how to build myself custom primitive with my vertex data?
some shape that the Entity is not support.
or how can I search some useful Information to build it.
Thanks a lot.
Hi Zhao,
While a little less simple than working with the Entity API, you can try using the lower-level geometries.
Hope that helps.
Thanks!
Gabby
Hi Gabby,
Thank you very much for your reply.This is my Problem:
I can’t use primitive like BoxGeometry too, because I want to build a geometry like tetrahedron ,4 vertex or 5 vertex…
and I can’t find any information in sandbox or your tutorials.Can you give me some guidance?
By the way, I found some images of sensor in your cesiumPro.
How can I get cesiumPro and How to buy it?
Thanks a lot.
在 2017年10月21日星期六 UTC+8上午2:48:19,Gabby Getz写道:
Hi Zhao,
I think the closest you could get is create a PolylineGeometry and extrude the height for a volume. If that’s not sufficient, could you perhaps create a model from your data?
Email todd@agi.com for info on CesiumPro.
Thanks!
Gabby
For custom geometry, check out https://github.com/AnalyticalGraphicsInc/cesium/wiki/Geometry-and-Appearances
