How can I combine all the modules into one, without requests
Our site did not pass the test for page speed insights, and I would like to know if it is possible to combine all the modules into one file, avoiding requests. https://www.screencast.com/t/6qxxuSJgp1
Can you help me, what is best way to do this with webpack ?
My webpack configuration
const webpack = require(‘webpack’);
const path = require(‘path’);
const os = require(‘os’);
const cores = os.cpus().length;
const TerserJsPlugin = require(‘terser-webpack-plugin’);
const CopyWebpackPlugin = require(‘copy-webpack-plugin’);
const LodashModuleReplacementPlugin = require(‘lodash-webpack-plugin’);
const isDev = process.env.NODE_ENV === ‘development’;
const srcPath = ‘./app/scripts/pages/’;
const cesiumSource = ‘node_modules/cesium/Source’;
const cesiumWorkers = ‘…/Build/Cesium/Workers’;
module.exports = (watch = false) => ({
mode: isDev ? ‘development’ : ‘production’,
entry: {
home: ${srcPath}home.js,
calculator: ${srcPath}calculator.js,
output: {
path: path.join(__dirname, ‘./dist/assets/scripts/’),
filename: ‘[name].min.js’,
sourcePrefix: ‘’
amd: {
toUrlUndefined: true
node: {
fs: ‘empty’
resolve: {
alias: {
cesium: path.resolve(__dirname, cesiumSource)
watch,
devtool: ‘’,
module: {
unknownContextCritical: false,
rules: [{
test: /.(png|gif|jpg|jpeg|svg|xml|json)$/,
use: [‘url-loader’]
test: /.js$/,
enforce: ‘pre’,
include: path.resolve(__dirname, cesiumSource),
use: [{
loader: ‘strip-pragma-loader’,
options: {
pragmas: {
debug: false
test: /.js$/,
exclude: /node_modules/,
use: [
loader: ‘cache-loader’,
options: {
cacheDirectory: path.resolve(
__dirname,
‘node_modules/.cache/cache-loader’
loader: ‘thread-loader’,
options: {
poolTimeout: Infinity
‘babel-loader’
optimization: {
noEmitOnErrors: false,
minimizer: [
new TerserJsPlugin({
cache: true,
parallel: true,
terserOptions: {
compress: isDev ? false : true,
ecma: 6,
mangle: true
extractComments: false,
sourceMap: false
splitChunks: {
cacheGroups: {
commons: {
test: /[\/]node_modules[\/]cesium/,
chunks: ‘all’,
filename: ‘cesium.bundle.js’
plugins: [
new CopyWebpackPlugin([{from: path.join(cesiumSource, cesiumWorkers), to: ‘Workers’}]),
new CopyWebpackPlugin([{from: path.join(cesiumSource, ‘Assets’), to: ‘Assets’}]),
new CopyWebpackPlugin([{from: path.join(cesiumSource, ‘Widgets’), to: ‘Widgets’}]),
new webpack.DefinePlugin({
‘process.env’: {
NODE_ENV: JSON.stringify(process.env.NODE_ENV || ‘development’),
CESIUM_BASE_URL: JSON.stringify(’./assets/scripts/’)
new LodashModuleReplacementPlugin,
new webpack.optimize.ModuleConcatenationPlugin(),
I don’t think this can be avoided, since those files that are not built into the Cesium.js are web workers, which must be loaded as separate scripts.
You can read about using Cesium with webpack here: https://cesium.com/docs/tutorials/cesium-and-webpack/
Hope this helps!
Thanks for the reply!
Unfortunately, I already configured the assembly to the maximum, i found everything, but these requests confused me :slight_smile: Sorry for bad English
