how can I get the coordinates of the 4 vertices of the rectangle?
Hi all,
i have a rectangle entity. i want to get the coordinates of the vertices to calculate. how can I do that ?
How did you create the rectangle entity? Normally you’d pass a coordinates property, which would be a Rectangle instance (see https://cesium.com/docs/cesiumjs-ref-doc/RectangleGraphics.html?classFilter=RectangleG#coordinates). So you can take the longitude and latitude of the top left and bottom right corners of the rectangle, and convert those to Cartesian3 with the cartographic class (see https://cesium.com/docs/cesiumjs-ref-doc/Cartographic.html?classFilter=Cartog#.toCartesian).
Let me know if that helps.
thanks you Omar. it work!
Vào 06:16:17 UTC+7 Thứ Hai, ngày 28 tháng 10 năm 2019, Omar Shehata đã viết:
