sx_dev
September 9, 2021, 9:22am
1
Hello guys,
I’m newbie of cesiumjs.
As the image, I want to access to the polygon added on the cesium.viewer.
how do I access the properties like written at here(height, extrudedHeight etc )?
http://localhost/CesiumIonSDK/Build/Documentation/PolygonGeometry.html?classFilter=polygon
thanks team
Hiroshi
fation
September 9, 2021, 11:19am
2
var viewer = new Cesium.Viewer(“cesiumContainer”, {
terrainProvider: Cesium.createWorldTerrain(),
polygon: {
hierarchy: new Cesium.PolygonHierarchy(
Cesium.Cartesian3.fromRadiansArray([
-1.3194369277314022,
0.6988062530900625,
-1.3193955980204217,
0.6988091578771254,
-1.3193931220959367,
0.698743632490865,
-1.3194358224045408,
0.6987471965556998,
material: Cesium.Color.RED.withAlpha(0.5),
classificationType: Cesium.ClassificationType.BOTH,
viewer.zoomTo(entity)
console.log(entity.polygon)
I guess that you want to get some properties from points of point cloud dropped in the drawn polygon.
am I right?
sx_dev
September 10, 2021, 1:25am
4
Hello @ZhefengJin . this is Hiroshi. I hope you realize me.
Yes you are right. Thanks for the clarification.
Maybe
1 make sure that your pointcloud has a batch table.
2 get Cesium3DTileFeatures contained in the given polygon.
3 access necessary properties via Cesium3DTileFeature 's API.
Hi @ZhefengJin .
Can you give some tips to get Cesium3DTileFeatures contained in the given polygon.?
Thanks for your support.
Best
Moises
