How I can get time index of the entity?
I want to take current time. It should be change over time. There is no iteration in my code. I will take position of an object so I tried this.
var mainObjPos =entity.position.getValue(viewer.clock.currentTime);
in getValue I feed currentTime but it did not change over time. It gave only one sample.
function computeCirclularFlight(height) { //this is the path of vehicle
var property = new Cesium.SampledPositionProperty();
for (var i = 0; i <= 74; i += 6) {
var time = Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate());
var position = Cesium.Cartesian3.fromDegrees(lon_lat[i], lon_lat[i+1], height);
property.addSample(time, position);
return property;
var position = computeCirclularFlight(0.5);
//Set the entity availability to the same interval as the simulation time.
availability : new Cesium.TimeIntervalCollection([new Cesium.TimeInterval({
start : start,
stop : stop
position : position,
orientation : new Cesium.VelocityOrientationProperty(position),
model : {
uri : ‘…/…/…/…/Apps/SampleData/models/CesiumMilkTruck/CesiumMilkTruck.glb’,
minimumPixelSize : 8,
scale: 1,
maximumScale: 2
var mainObjPos = entity.position.getValue(viewer.clock.currentTime); // i think issue is here
var objEntity = viewer.entities.add({
position : mainObjPos,
model : {
scale: 1,
maximumScale: 2
So I want to change an entity’s position which respect to another entity.
Lastest version, Opera, Win7.
So could you help me to take time index or exact position of the first entity?
It’s hard to tell what the issue is from the code sample (for example, how do you define your “start” and “stop” variables? Providing a complete Sandcastle example helps), but have you verified that the viewer is set to advance simulation time? By default, the viewer sets shouldAnimate to false.
I added to code below, I would like to move objEntity which respect to entity. Thank you.
infoBox: false, //Disable InfoBox widget
selectionIndicator: false, //Disable selection indicator
shouldAnimate: true, // Enable animations
//terrainProvider: Cesium.createWorldTerrain()
//Enable lighting based on sun/moon positions
viewer.scene.globe.enableLighting = true;
//Enable depth testing so things behind the terrain disappear.
viewer.scene.globe.depthTestAgainstTerrain = true;
//Set bounds of our simulation time
var start = Cesium.JulianDate.fromDate(new Date(2015, 2, 25, 16));
var stop = Cesium.JulianDate.addSeconds(start, 74, new Cesium.JulianDate());
var current = Cesium.JulianDate.now();
//heading of the model object
var heading = Cesium.Math.toRadians(90.0);
var pitch = Cesium.Math.toRadians(0);
var roll = Cesium.Math.toRadians(0);
var hpRoll = new Cesium.HeadingPitchRoll(heading,pitch,roll);
var fixedFrameTransform = Cesium.Transforms.localFrameToFixedFrameGenerator(‘south’, ‘west’);
viewer.clock.startTime = start.clone();
viewer.clock.stopTime = stop.clone();
viewer.clock.currentTime = start.clone();
viewer.clock.clockRange = Cesium.ClockRange.LOOP_STOP; //Loop at the end
viewer.clock.multiplier = 0.2;
viewer.timeline.zoomTo(start, stop);
var lon_lat = [29.207734,41.0220831,
29.2102525,41.0200434,
29.206165,41.0178572,];
var time_array = ;
for (var i = 0; i <= 5; i += 2) {
time_array.push(time);
//Also create a point for each sample we generate.
point : {
pixelSize : 6,
color : Cesium.Color.TRANSPARENT,
outlineColor : Cesium.Color.GREEN,
outlineWidth : 1
return [property,time_array];
var [position,timing] = computeCirclularFlight(0.5);
console.log(timing);
var positionOfLabel = computeCirclularFlight(5);
var positionOfLabel = positionOfLabel[0];
start : start,
stop : stop
//Use our computed positions
//Automatically compute orientation based on position movement.
//Load the Cesium plane model to represent the entity
model : {
scale: 1,
maximumScale: 2
//Show the path as a pink line sampled in 1 second increments.
path : {
resolution : 1,
material : new Cesium.PolylineGlowMaterialProperty({
glowPower : 0.1,
color : Cesium.Color.YELLOW
width : 10
//tracked object is vehicle
var labelEntity = viewer.entities.add({
position: positionOfLabel,
label : {
text: ‘phil’,
verticalOrigin: Cesium.VerticalOrigin.TOP
path : {
resolution : 1,
glowPower : 0.1,
width : 10
var timeofObj = Cesium.JulianDate.addSeconds(start, 5, new Cesium.JulianDate());
var objPosition = Cesium.Cartesian3.fromDegrees( 8.29458,49.0682,0.5);
position : entity.position.getValue(current),
model : {
scale: 1,
maximumScale: 2
//interpolation part, there should be one interpolation for each line that the code draw
entity.position.setInterpolationOptions({
interpolationDegree : 2,
interpolationAlgorithm : Cesium.LagrangePolynomialApproximation
labelEntity.position.setInterpolationOptions({
Thank you for providing your full code. I think I understand what you’re trying to do now.
You can verify that getValue is working by getting its output every frame:
function tick() {
console.log(entity.position.getValue(viewer.clock.currentTime));
Cesium.requestAnimationFrame(tick);
tick();
And you can see that it does change as it moves. Now if you want to set an entity’s position to something that’s not constant (like another entity’s moving position) then you can use a CallbackProperty.
So instead of:
position : entity.position.getValue(viewer.clock.currentTime)
Try:
position : new Cesium.CallbackProperty(function(){
return entity.position.getValue(viewer.clock.currentTime)
},false)
Here’s a running example. I made the second milk truck bigger to verify that it is moving with the other entity.
