You can add some custom camera keyboard events as detailed in our camera tutorial: http://cesiumjs.org/tutorials/Camera-Tutorial/
You'll probably want to use camera.LookUp, which takes a rotation angle in radians.
On Wednesday, April 19, 2017 at 6:10:11 AM UTC-4, anser...@gmail.com wrote:Hi,
I don't want to use mouse to control the camera tilt angle,so I put it away
"viewer.scene.screenSpaceCameraController.tiltEventTypes = undefined;"
Then I want to use keyboard to control it. But I can't do that like mouse.
I just want to set some fixed angles by the keyboard,What should I do?
Anseru
Hi Rachel,
I want to tilt,just like Cesium.CameraEventType.MIDDLE_DRAG. The Camera rotation can't do that.
I think one way to do this is to fix the camera’s reference frame at a point, then use the camera rotate functions. Here’s a Sandcastle example orbitting a point on a line.
This thread has a similar question and some more Sandcastle code examples to do it:
