How to calculate whether the point is online?
I have a line, How to calculate whether any point on the line overlaps with the line?
The coordinates are:
let coord = [-122.42166597493569, 37.66877558477902, -122.4188713733115, 37.669448382889094, -122.41642921573572, 37.66916144609525, -122.4146827046525, 37.66834407434515]
viewer.entities.add({
        polyline: {
          positions: Cesium.Cartesian3.fromDegreesArray(coord),
          width: 13,
          clampToGround: true,
          material: Cesium.Color.RED,
Hi @mcck,
Welcome to the community! Thank you for bringing us your question! It seems like you have created a polyline. How do you intend to add points to the scene?
-Sam
I want to determine whether the created point overlaps the line。
Add point:
	var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
	handler.setInputAction(function(movement){
		let cartesian = viewer.scene.globe.pick(viewer.camera.getPickRay(movement.position), viewer.scene);
		let point = viewer.entities.add({
			position: cartesian,
			point: {
			  color: Cesium.Color.WHITE,
			  pixelSize: 5,
			  heightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
			  outlineColor: Cesium.Color.BLACK,
			  outlineWidth: 1
		if( xxx ){ // Do points and lines overlap
			// overlap
		} else {
			// No overlap
Something like this?
        var feature = scene.pick(movement.endPosition);
			point: {
			  pixelSize: 5,
			  outlineWidth: 1
		if( feature == myPolylineEntity ){ // Do points and lines overlap
			// overlap
		} else {
			// No overlap
If lots of entities end up in the near vicinity of each other, you move to scene.drillPick() and sift through the resulting array for your polyline entity instead.
Cheers,
Alex
thank you,If I don’t have windows position and only have Cartesian 3, how can I judge
I think in your example I modified, movement.endPosition should be movement.position. You’re using the screen position there to create the ray that returns the Cartesian3, so in a sense you’ve got both.
Cheers,
Alex
Maybe my expression is wrong. I only have cartesian3 now. I want to judge whether cartesian3 overlaps with polyline, windowPosition is just a test
Hello @mcck,
I have a similar problem (only to determine if a point is in a given area) and I thought about it a lot - I think that using a corridor instead of a polyline can help you - it has a height -
https://cesium.com/learn/cesiumjs/ref-doc/CorridorGeometry.html?classFilter=cor
this is how intersection tests can be used
https://cesium.com/learn/cesiumjs/ref-doc/IntersectionTests.html
here you can fantasize:
1 you can direct a ray from a point and determine its intersection with a primitive
2, you can define the intersection of the corridor primitive and the dimension sphere of the entity with the geometry of the point
  • there are a lot of pitfalls - I will not say exactly from memory now - however, there are definitely opportunities - when I have time, I will also return to the implementation of my tool and perhaps write more accurately with code examples. So far, I am only suggesting the direction of a possible solution.
    Hope this helps you.
Maybe I should change the way. I thought about it. I don’t have to use polyline to realize this. Thank you very much for your suggestion
