I am not able to compute the new position correctly. I have distance and previous cartesian coordinates. On adding, it doesn’t seem to compute new position correctly. I want my path to be midway between red path and yellow path.
//Use STK World Terrain
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
url : ‘https://assets.agi.com/stk-terrain/v1/tilesets/world/tiles’,
requestVertexNormals : true
//Set the random number seed for consistent results.
Cesium.Math.setRandomNumberSeed(3);
var start = Cesium.JulianDate.fromDate(new Date());
var stop = Cesium.JulianDate.addSeconds(start, 360, new Cesium.JulianDate());
var a = ;
var b = ;
function computeFlightPath(lon, lat, radius, index) {
var count = 0;
var pos = new Cesium.SampledPositionProperty();
for (var i = 0; i <= 270; i += 15) {
var radians = Cesium.Math.toRadians(i);
var time = Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate());
var position = Cesium.Cartesian3.fromDegrees(lon + (radius * 1.5 * Math.cos(radians)), lat + (radius * Math.sin(radians)), Cesium.Math.nextRandomNumber() * 500 + 1750);
pos.addSample(time, position);
if(index === 1){
a[count] = pos.getValue(time);
if(index === 2) {
b[count] = pos.getValue(time);
//Also create a point for each sample we generate.
if(index === 1) {
viewer.entities.add({
position : position,
point : {
pixelSize : 8,
color : Cesium.Color.TRANSPARENT,
outlineColor : Cesium.Color.YELLOW,
outlineWidth : 3
if(index === 2) {
point : {
pixelSize : 8,
outlineColor : Cesium.Color.RED,
outlineWidth : 3
count++;
return pos;
function computeFinalFlightPath(d, a, b) {
console.log(a);
var property = new Cesium.SampledPositionProperty();
for (var i = 0; i < a.length; i ++) {
var position = Cesium.Cartesian3.fromElements(a[i].x + (0.5d[i]), a[i].y + (0.5d[i]), a[i].z);
property.addSample(time, position);
point : {
pixelSize : 8,
outlineColor : Cesium.Color.CYAN,
outlineWidth : 3
return property;
//Compute the position
var position = computeFlightPath(-83.60986232757568,41.653258658953995, 0.03, 1);
var position1 = computeFlightPath(-83.60986232757570,41.653258658953998, 0.033, 2);
var d = ;
for(i=0;i<a.length;i++){
d[i] = Cesium.Cartesian3.distance(a[i], b[i]);
//console.log(d);
//console.log(a);
//console.log(b);
var positionFinal = computeFinalFlightPath(d,a,b);
availability : new Cesium.TimeIntervalCollection([new Cesium.TimeInterval({
start : start,
stop : stop
//Use our computed positions
//Automatically compute orientation based on position movement.
orientation : new Cesium.VelocityOrientationProperty(position),
path : {
resolution : 1,
material : new Cesium.PolylineGlowMaterialProperty({
glowPower : 0.1,
color : Cesium.Color.YELLOW
width : 10
var entity1 = viewer.entities.add({
start : start,
stop : stop
position : position1,
path : {
resolution : 1,
glowPower : 0.1,
color : Cesium.Color.RED
width : 10
var entity2 = viewer.entities.add({
start : start,
stop : stop
position : positionFinal,
path : {
resolution : 1,
glowPower : 0.1,
color : Cesium.Color.CYAN
width : 10
Estimated Corridor Averaging
Start with two sets of overlapping posit tracks and
For each track
for each posit
assume the posit is perfectly in the center of the air corridor, compute and store the coordinates of the default sized corridor slice.
Since the UAVs will fly similar, but not exactly the same paths, when following a corridor the slice coordinates for each UAV path will be different
For a set of UAV paths
find closest UAV 1 and UAV 2 posits and average them to generate a reference path
compute a corridor slice for each posit on the reference path
interpolate the geometry between each slice to have a closed form 3D shape for the corridor
Visualize by rendering the 3D shape to your map
The distance between the coordinates in the individual coordinate sets indicates the possible error/uncertainty in the estimation.
Cesium-1.42, Windows 10, Mozilla Firefox
