Midpoint of two Cesium Cartesian3 Coordinates
How do I calculate the midpoint of two Cesium Cartesian3 Coordinates. Like I’m able to compute the distance. However, how can I compute the coordinates of the midpoint?
A little vector math is all we need here.
// Define a couple of points
var p1 = Cesium.Cartesian3.fromDegrees(-73.966250, 40.783430); // New York
var p2 = Cesium.Cartesian3.fromDegrees(-122.419420, 37.774930);// San Francisco
// Compute vector from p1 to p2
var p1p2 = new Cesium.Cartesian3(0.0, 0.0, 0.0);
Cesium.Cartesian3.subtract(p2, p1, p1p2);
// Compute vector to midpoint
var halfp1p2 = new Cesium.Cartesian3(0.0, 0.0, 0.0);
Cesium.Cartesian3.multiplyByScalar(p1p2, 0.5, halfp1p2);
// Compute point half way between p1 and p2
var p3 = new Cesium.Cartesian3(0.0, 0.0, 0.0);
p3 = Cesium.Cartesian3.add(p1, halfp1p2, p3);
// Force point onto surface of ellipsoid for visualization.
var midPt = Cesium.Cartographic.fromCartesian(p3);
var p3a = Cesium.Cartesian3.fromRadians(midPt.longitude, midPt.latitude, 0.0);
viewer.entities.add({
position: p1,
point: {
    color: Cesium.Color.DODGERBLUE,
    pixelSize: 10,
    outlineColor: Cesium.Color.WHITE,
    outlineWidth: 3
position: p2,
point: {
    pixelSize: 10,
    outlineWidth: 3
position: p3a,
point: {
    color: Cesium.Color.GOLD,
    pixelSize: 10,
    outlineWidth: 3
Hope that helps.
Scott
Thank you Scott! Your help is greatly appreciated! I have a doubt though. When I have cartesian3 coordinates in the form of x, y, z, isn’t the basic midpoint formula of a straight line applicable here. I’m confused as we are dealing with cartesian3 coordinates, right? So, the midpoint can’t be (x1+x2)/2, (y1+y2)/2? Just curious to know why this is not applicable here?
That would work too. I tend to think in vectors.
Why ask for help when you have a solution?
Your solution seems to be a better approach. I had a basic idea of a straight line. I don’t think that will work when I am trying to average two paths to create a reference path. I wasn’t sure of the solution. So, I thought of seeking help on the issue. Thank you Scott! I appreciate it much!
