for example, I’d like to get the center position from these 2 points below, into cartesian.
0: Cartesian3 {x: -3921995.456462748, y: 3367306.592566854, z: 3723758.4693907322}
1: Cartesian3 {x: -3922122.4638296547, y: 3367281.335349712, z: 3723648.2789329886}
I’ve made it like this below.
cartesian => latitude, longitude pair => calculate the center
initEntityBetweenPoint(pathWithLatLng,options,ClassName){
// should be like this
// pathWithLatLng = [139.3516098083, 35.9506299352, 139.3527392288, 35.9494031955];
let pairArray = this.combineLngLatTwoPair(pathWithLatLng);
var _this = this;
var entities = pairArray.map(function(pairObject) {
let centerPositionCarto = _this.getCenterPositionBetweenPoint(pairObject);
let position = _this.cesium.Cartesian3.fromRadians(
centerPositionCarto.longitude,
centerPositionCarto.latitude,
return new ClassName(_this.cesium,_this.viewer,position,options);
return (entities.length>0) ? entities : ;
combineLngLatTwoPair(path,isRounded=false) {
const pathToPair = path.reduce(function(result, value, index, array) {
if (index % 2 === 0) {
const pairedArray = array.slice(index, index + 4);
if(pairedArray.length == 4) {
result.push({
lng1:pairedArray[0],
lat1:pairedArray[1],
lng2:pairedArray[2],
lat2:pairedArray[3]
else if( isRounded && (index+2) == array.length){
result.push({
lng1:path[0],
lat1:path[1],
lng2:pairedArray[0],
lat2:pairedArray[1]
return result;
return pathToPair;
getCenterPositionBetweenPoint(pairObject) {
let startPoint, endPoint, geodesic, positionCarto;
startPoint = new this.cesium.Cartographic.fromDegrees(pairObject.lng1, pairObject.lat1);
endPoint = new this.cesium.Cartographic.fromDegrees(pairObject.lng2, pairObject.lat2);
geodesic = new this.cesium.EllipsoidGeodesic(startPoint, endPoint);
positionCarto = geodesic.interpolateUsingFraction(1/2);
return positionCarto;
to set some label on it between 2 points.
ver 1.59
