how to convert multiple 3d formats(dwg, dgn, nwd, obj, 3mx, stl, fbx,3ds) to glTF
If you can convert the file to Collada (.dae) or obj, then you can use the online converter.
Gabby
Also check out http://assimp.sourceforge.net/
