How to display feature data with czml
Hi Cesium community,
I’m new to Cesium and have been working through the tutorial at Introduction to Cesium Stories – Cesium. I’ve encountered an issue where I’m unable to view feature data. After inspecting the provided CZML file, I noticed it lacks metadata. I attempted to manually add metadata by including a “properties” attribute in the CZML file, but this did not result in the display of a table. However, when I added a “description” attribute, the text from the description was displayed.
I also downloaded a GeoJSON file from https://data.melbourne.vic.gov.au/, which successfully displayed metadata associated with its properties attribute.
My question is: Can CZML files display metadata in the same way that GeoJSON files do? If so, how can I achieve this?
Welcome to the Cesium community @J3ORGE!
Cesium Stories does not currently display data from the properties section in the user interface. The description field does support HTML, so you can add a HTML table with property information. See this example:
Stories_CZML_Metadata.czml (1.0 KB)
Please let us know if this works for you.
