how to get current camera parameter
When initializing map, I set camera parameter,
  viewer.camera.setView( {
        destination : Cesium.Cartesian3.fromDegrees(116, 39, 100000),// x y z
        orientation: {
            heading : Cesium.Math.toRadians(-0),
            pitch : Cesium.Math.toRadians(-40),
            roll : 0.0
When users drag map , change map direction , I wanto to save z, but reset x and y. In the console , I output the viewer.camera, find the parameter( position, direction ) value is very large, not use degree, how to get the parameter (using degree), thanks!
Hi there,
Here’s a code example that prints the camera values in degrees on button click.
Hope that helps,
  • Rachel
