Is there a way to get camera orientation values like heading, pitch, tilt, roll as i set the camera view on cesium globe dynamically?
Is there a way to get camera orientation values like heading, pitch, tilt, roll as i set the camera view on cesium globe dynamically ?
You can get the values by calling it as a member variable, for instance camera.pitch. Documentation for camera can be found here.
Hi Dzung,
Thanks for replying.
Yes i am too playing around this to get these as members.
Incase you found some working example, please share.
Kulvinder Singh
Check this sandcastle
Thanks @11115
Can we get these values on click instead of camera changed event ?
It’s like i choose a view and set it on a city, click on the city and lock the view. Now i want the camera orientation values.
Thanks in advance
You can look into the setInputAction. Here is a sandcastle example of how you can get the camera orientation values by left clicking the view port.
Much thanks @dzung
Hi @dzung,
I am trying to capture camera height and tilt, used the following but not able to, can you please check if these are the correct nvps:
(viewer.camera.tilt) == return undefined
(viewer.camera.height) == return undefined
(viewer.camera.altitude) == return undefined
The camera has a position vector (viewer.camera.position) that you can extract height from.
