How to keep click and drag to move camera behavior after a call to Camera#lookAt ?
I would like to enable the ability to click and drag to move the camera while maintaining a constant height above the ellipsoid as in the demo on the Cesium homepage. I would also like to initialize the camera to be looking at a particular point from a particular distance away with a particular orientation.
If I do not make a call to camera#lookAt this click and drag to move the camera behavior works as I would like it to. After I make a call to camera#lookAt, the click and drag behavior is to pivot around the target specified.
  const cartoTarget = Cesium.Cartographic.fromDegrees({{location.latLng.longitude}}, {{location.latLng.latitude}}, heightAboveEllipsoidM);
  const target = Cesium.Cartographic.toCartesian(cartoTarget);
  viewer.camera.lookAt(target, new Cesium.HeadingPitchRange(heading, pitch, range));
Just seeking the desired behavior. Open to suggestions.
I am using Cesium 1.43, macOS 10.13.3, Chrome 65.0.3325.162
After you call lookAt, add this line:
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
To reset the camera controls to what you are looking for.
Gabby
