In Cesium, Shift+Click+Dragging changes view while leaving the camera stationary and Control+Click+Dragging leaves the view point stationary while moving the camera. In the Google Earth plugin and in the Google Earth application, the Shift/Control dragging behavior is the opposite.
Is there example code that shows how to change this? I know how to trap for the shift and control keys (I'm doing that in conjunction with the arrow keys to mimic Google Earth's camera behavior), but I don't know how to change the behavior in Cesium.
Cesium has a class ScreenSpaceCameraController for setting which input control the camera. You can switch the modifiers on look and tilt to get the behavior you want. Here is an example:
var cameraController = viewer.scene.screenSpaceCameraController;
cameraController.lookEventTypes.modifier = Cesium.KeyboardEventModifier.CTRL;
cameraController.tiltEventTypes[2].modifier = Cesium.KeyboardEventModifier.SHIFT;
cameraController.tiltEventTypes[3].modifier = Cesium.KeyboardEventModifier.SHIFT;
