How to keeping pitch of model with VelocityOrientationProperty?
Hi I am implementing a simulation of a drone model in cesium.
The position of the drone has a SampledPositionProperty and I am using VelocityOrientationProperty for orientation.
I want the drone to move in a horizontal state (I think this is when the pitch is 0).
I tried modifying the VelocityOrientationProperty.js, but the direction the drone is looking is different from the direction it is traveling.
If you have any ideas, I would appreciate it.
Hi there,
Do you know if the drone model has the correct forward axis?
It may help if you post a Sandcastle example with a minimal code snippet.
Hi, I was able to find a sandcastle with something similar.
Hello World - Cesium Sandcastle
I added a bit of calculation to this example to get the angle and was able to get the results I wanted.
thanks for response.
