Hi everyone,
I'm trying to load a city with Cesium but i cant find the proper way to do it.
First a try loading KML files, but adding terrain is not compatible while using kml.
Then i try to use either gltf/glb format or 3D tiles, but i found some problems:
- The original dataset is on CityGML format. I used the 3Dcity-importer-exporter tool to generate GLTf files (one per building). How can i load all of the files together?
- Other option is to use the Binary-gltf-utils tool in order to obtain .glb files from the .gltf and then use 3d-tiles-tools to convert these new files into .b3dm, but the problem here is that the tileset.json file is not generated. How can this be done?
Any help or suggestions would be appreciated
