i im finding solution to pass click event from iframe to cesium viewer
in my webpage, i put an iframe element over the cesium container ,
and the iframe element is 100% cover the cesium container, 80% of the iframe is transpanrent and that is where need to pass through mouse event
the interface****dispatchEvent in the code below can trigger the click event of window ,but cesium viewer do not recerive it。
i have try the css pointer-events:none ,but it will disable all the click of the element inside of the iframe and set the div’s in the iframe to pointer-events:all is not work too
var event = document.createEvent(‘MouseEvents’);
event.initMouseEvent(‘click’, true, true, window, e.detail, e.screenX, e.screenY, e.clientX, e.clientY,
e.ctrlKey, e.altKey, e.shiftKey, e.metaKey,
e.button, e.relatedTarget);
window.dispatchEvent(event);
odd and complex demand of our production design,and the iframe is the easiest way to do it
cesium:1.43.0
os:windows 10
browser:chrome 70
ps:this is my first time to ask a question in english , sorry for my bad english
