Hi guys.
My team and I are trying to implement a function that will take our current satellite orbits and project the image onto the Earth's surface. However, our current attempt only displays wavy lines somewhere near Africa.
Our current implementation is as follows:
drawGroundTrack : function(viewer, dataSourceObject)
var pos = ;
var satPositions = dataSourceObject.position.cartesian;
var latLongPos = null;
for (var i = 1; i < satPositions.length; i += 4)
latLongPos = Cesium.Ellipsoid.WGS84.cartesianToCartographic(new Cesium.Cartesian3(satPositions[i], satPositions[i + 1], satPositions[i + 2]));
pos.push(Cesium.Cartesian3.fromDegrees(latLongPos.longitude, latLongPos.latitude));
latLongPos = null;
viewer.entities.add({
polyline : {
positions : pos,
width : 1.0,
material : new Cesium.PolylineGlowMaterialProperty({
color : Cesium.Color.DEEPSKYBLUE,
glowPower : 0.25
The data for satellites are generated on a backend server and the positions are sent via CZML. A sample of the data:
"position":{
"interpolationAlgorithm":"LAGRANGE",
"interpolationDegree":5,
"referenceFrame":"INERTIAL",
"epoch":"2015-08-01T12:40:20Z",
"cartesian":[
0,11819242.705263585,7972431.135792671,4811666.251546643,
300,10731415.381943967,8072935.194237854,3253712.8462225525,
600,9497296.045803875,8062819.782944127,1652163.8659633754,
We also tried using EllipsoidGeodesic but with no luck. Could you guys please give us some advice on how to solve this problem?
Thanks.
