Hi all,
I am trying to read and parse meshes (positions) from a b3dm file.
For instance, I know the following things from the parsed gltf:
buffers:
binary_glTF:
byteLength: 61977
type: “arraybuffer”
uri: “data:,”
bufferViews:
ID100:
buffer: “binary_glTF”
byteLength: 52200
byteOffset: 1077
target: 34962
accessor:
ID113:
bufferView: “ID100”
byteOffset: 0
byteStride: 24
componentType: 2126
count: 2175
max: Array[3] [-56.52291, 53.968422, -104.452774]
min: Array[3] [-190.10187, 34.01508, -277.79056]
type: “VEC3”
I am reading the coordinates in the following way:
function decodeVertices(glb, bufferView, rtc) {
var count = 2175; // number attributes
var byt = 4; // byte
var byteStride = 24; // stride between the elements
var dv = new DataView(glb.buffer, bufferView.byteOffset, bufferView.byteLength);
var res = ;
for (var i = 0, j = 0; i < count; i += 3, j += byteStride) {
var val = new Array(3);
val[0] = dv.getFloat32(j, true);// + rtc.center[0]; // get first component
val[1] = dv.getFloat32(j + (byt * 1), true);// + rtc.center[1]; // get second component.
val[2] = dv.getFloat32(j + (byt * 2), true);// + rtc.center[2]; // get third component.
res[i] = val;
console.log('Vals: ’ + val[0] + ', ’ + val[1] + ', ’ + val[2]);
return res;
I get the following results:
Vals: 7.207591074455699e+31, 3.231399467707032e-18, 2.577634550249286e-9
Vals: 2.52259088235218e-18, 6.409691111208815e-10, 3.136870305473835e+27
Vals: 2.7086146658916732e-9, 0.00004367362998891622, 1.4250735797288833e+22
Vals: 2.522595018255243e-18, 1.1721528993864758e+27, 2.308287458743785e-12
Vals: 2.920964398020279e+32, 4.5448218236123114e+30, 4.8393493987304744e+30
Vals: 3.2850787331732012e-18, 6.480466163694132e-10, 3.602292509424787e-12
When adding the rtc.center coordinates, some positions look fine, but some don’t. Especially, some huge values (e.g. the first one 7.207591074455699e+31) make me skeptical.
Am I doing something fundamentally wrong? Or is there another way to read the positions of the meshes?
Thanks in advance!
